1 - 5 of 5 Posts
Hey guys, I bought Megan Racing EZ Street coilovers a while back and they have been really good. its a great ride. I want to go lower, but the spring rates aren't stiff enough... i keep rubbing fender. Right now there at F: 8kg/mm-447lbs/inch R: 6kg/mm-335lbs/inch . my question is, Where can i get get stiffer springs and what load rating should i get? thanks
Official Armchair Racer
Figure out what dimensions the springs are then start shopping. Qa1, swift, eibach ers, hypercoil etc..
Thanks guys. someone said they run 12/8 and its stiff enough. I'll get in touch with megan racing and see what they offer. and then try the above references. I'm looking for springs about 160mm in length
B&G suspension can offer you racing springs (61mm diameter inside)
Or Cobra-suspension (61mm) can make you anything you need
I am running 140mm long and 70KG's in the back without spacer spring on the mx5
1 - 5 of 5 Posts
