1 - 2 of 2 Posts
Hey guys Im a little stumped. The OEM door lock switch is has two wires coming from it and I'm trying to figure out how to wiring it into my aftermarket alarm.
The aftermarket alarm uses a negative pulse on two relays to lock or unlock the doors.
It essentially looks like this
My assumption is that I need to have a 3 way switch that will provide a negative input that will trigger either of the relays. The only problem is that the OEM switch only has 2 wires coming from it. So how do I get this to work?
Thanks!
-B
Discussion Starter · #2 ·
Okay here's the solution! Thanks to Mikey P from Miata.net for the diagram. This will allow you to modify the OEM lock switch to work with an aftermarket alarm.
Here's a video of the switch in action:
1 - 2 of 2 Posts
