Tap at cold startup.
745 views 6 replies 5 participants last post by  3MiataFamily
#1 ·
Yes I'm aware of the infamous lifter tick at normal start-ups but this seems far worse. When the car has sat overnight in some pretty cold nights - I get a very, very loud tap at original startup which does not go away if I leave it running. (Well I've been too afraid to let it run too long to see if it actually would go away. Longest I've done was about 5 minutes). I have to shut the engine down, and restart it then it's as if it never happened. Quite honestly, all I need to do to remedy the tap is start - immediately shut off and then restart. I'm just worried something is going bad and I don't want to tear the top off if it's unnecessary at this point.
Anybody have any ideas or things I should look into? I bought this car to learn about mechanic work so I'm not very skilled but am willing to do what's necessary to learn and fix!
#2 ·
First is an oil change, then there would be HLA cleaning instructions on m.net in the garage.
It's not a knock and it will go away in a few minutes.
#3 ·
Yeah, do what the person above me said. It's probably getting cold around there at this point so you might want to switch to an oil that has a lower low-temp viscosity to see if that helps at all. Your symptoms remind me of when I did my timing belt change over two weeks and had the engine open the whole time. When I started the car back up I had a horrid, loud tapping sound that did not go away for at least 15 minutes. I turned the car off at that point and turned it on again, and it never came back.
Switch oil, Seafoam, etc. I think you'll be just fine.
#5 ·
Have you run Seafoam/equivalent through or done any of the recommended flushes? I'd start there first, change the oil and give it another go. For what it's worth, Mobil 1 10w30 has been great for my 1.6. I don't know if it was a combination of the flushes or what, but I have no cold tick, and hot tick only near the end of my oil change cycle (every 5-6k or so, I only change it once a year since I only drive the car from May>November).
#6 ·
I have not. Its on my winter to-do list. Its loud when I first fire it up in the morning, but then after about 5 seconds or so it quiets down considerably after a few revs. I have about 2k miles till I would need to do my next oil change, but I guess i can go ahead and do it early. Can't hurt. Thanks for the input Bronto.
